Ansys Learning Forum Forums Discuss Simulation Fluids ansys aqwa : ball connector and socket Reply To: ansys aqwa : ball connector and socket
Shuangxing Du
The items in the Joint Properties are optional. If there is no data being typed in, the default is zero.  For a ball and socket joint, its joint local axes coincide with the axis directions of the global coordinate system axes at the initial definition localtion.
