Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Import Parameterized Function (curve) from Solid Works to Workbench ? › Reply To: Import Parameterized Function (curve) from Solid Works to Workbench ?
July 10, 2024 at 1:01 pm
Hello
The SolidWorks plugin is capable of importing Global Variables which can then be driven from within the Ansys Parameters.
In my example here, a simple Global Variable "a" is exposed to the Parameter set. Note I had to change my parameter filter to include "a" so anything with "a" in the name will pass into Ansys.Â
The question for SW support is: Can you drive your X1 or X2 parameters with an equation value such as "a". Â
If yes, then it seems you can accomplish your task.Â
