Method to observe analysis result at each time step
    • JooJaehoon
      Hello
      I conduct structural analysis applying multi time s.tep
      I input different force condition at each time step.
      I want to observe stress, strain, deformation result at each time step.
      Is there a any method?
    • Aurojyoti Prusty
      I suppose you are doing a static structural problem and applying multiple load at different load step.
      After application of load in multistep, add stress, strain, deformation (directional or total) to the solution field and solve the model.
      Results from each load step (min, max, avg) will be available in each result like graph below (4 steps). Please let us know if this helps or you meant something else in the question.
      Thanks,
      Aurojyoti
      • JooJaehoon
        I want to check contour of stress, strain, deformation
  • The topic ‘Method to observe analysis result at each time step’ is closed to new replies.
