Ansys Learning Forum › Forums › Discuss Simulation › Fluids › High Mach Number, Compressible Flow 3D Simulation around a Finned Projectile › Reply To: High Mach Number, Compressible Flow 3D Simulation around a Finned Projectile
July 9, 2024 at 1:52 pm
5) Center of pressure will be dependent on your surface pressure solution on your projectile, so I recommend you make sure that your solution is correct, following some of my suggestions above, before working on this.
