nCode Result
    • Jeonee
      I did fatigue analysis in nCode DesignLife. I create 'Named Selection', and I can see the parts. When I want to see fatigue analysis result on these parts, half of the parts does not have any result. I think, this is bug.
    • danielshaw
      Are results missing or are they out-of-range?  For example, if the calculated stress range is greater than the UTS, DesignLife will not calculate fatigue damage, becasue is assumed that the component will fail with 1 cycle of loading.
      • Jeonee
        I can't see the result like this area. Fatigue results of some surfaces of the part are not visible. It looks like it's torn apart.
    • danielshaw
      Are the results for that area available in the DataValueDisplay table?  If so, then it is a graphics issue.  If not, then the solver did not calculate the results in that region.  Can you file a support case and provide the model?  If so, we can dig into deeper.
      • Jeonee
        The solver did not calculate the results. This image is an example. I did an analysis at university, so I'm so sorry, I cannot share the project.
      • Jeonee
        Hi sir,
        Is there any method to solve this problem? I could not find any information on the internet.
    • danielshaw
      Sorry, but I cannot debug this behavior without more information.  It might be a bug, but I doubt it.  What release are you using?  Did you try running the fatigue analysis using the Mechanical Add-On?
    • danielshaw
      If you are having difficulty with DesignLife graphics, you could plot the DesignLife results inside Mechanical.
      • Jeonee
        Thank you so much
Viewing 4 reply threads
  • The topic ‘nCode Result’ is closed to new replies.
