July 8, 2024 at 11:02 pm
Partho Partho
SubscriberQ3D Simulation for Misaligned Copper Conductors with Small Contact Areas: Unexpectedly Low Resistance Values
Hi everyone,
I'm facing an issue with Q3D while simulating the resistance of misaligned copper conductors. Here's my setup:
- Two vertical copper conductors, initially connected at the edge.
- One conductor is gradually moved horizontally to reduce the contact area.
The Problem:
Initially, Q3D produced resistance values close to my calculations. However, as the contact area decreased to the nm^2 range, the simulated resistance became much lower than expected. For instance, at a contact area where I expect over 20 Ohms, Q3D shows only 150 mOhm.
What I've Tried:
I've tried extensive mesh refinement, reaching sub-nm element sizes, but the issue persists.
My Question:
Is Q3D inherently limited in its ability to accurately calculate resistance for such small contact areas? Or am I missing a crucial setting or technique?
Any insights or suggestions would be greatly appreciated!
August 27, 2024 at 8:00 am
Mrinmoy Bharadwaj
Ansys EmployeeHello Partho Partho,
It is unlikely for the solver to have any such inherent limitation. Additionally, the provided information isn't sufficient to provide any suggestions on your settings. May be providing more information (snaps of your set-up, model, etc.) might help in giving a better suggestion.
- The topic ‘Ansys Q3D giving erroneous value.’ is closed to new replies.
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- Co-simulation in Q3D, Icepak – meshing problem
- Classic Icepak – clarifications on Boundary condition
- Link the Circuit to 3D Terminals
- Rectangular Coil in Maxwell for WPT using solid block
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- (HFSS) Surface Current on Microstrip Shows Impossible Current outside of Trace
4527
1494
1386
1209
