Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Issue calculating the Reynolds no. in Fluent › Reply To: Issue calculating the Reynolds no. in Fluent
July 4, 2024 at 2:19 pm
n should be N, ie Newtons. That's Fluent being case sensitive.
I checked this yesterday in 2024R1, but looks like the system ate both posts.
Double check what you're calculating, but also update to the current version. R19 would have been about the first release of Expressions and you may have found a problem.
