August 8, 2019 at 1:35 pm
Noushin
SubscriberDear Experts
Recently I am facing abnormal exit from fluent. I have gone through other posts related to this issue but none of them worked for me. I am currently using ANSYS 19.2 intel core i5 processor with 8GB RAM and 1TB HDD. Our simulation involves an UDF. It is to be noted that I have worked with this UDF in this device without any error previously.
We have deadline for our thesis, but due to this issue I am unable to perform any kind of simulation for the last three weeks. Please help me solving this problem. I am attaching snap shot from the transcript file and log file (Error-999999) with this post. If any more details is required please let me know.
Thank you.
Sincerely
Noushin
ERRor Message:
Trascript write_ part seven (at the 16th time step):
August 8, 2019 at 1:48 pm
Forum ModeratorThat looks more like a network problem than anything in Fluent. It's running fine then you've lost connection to something, the 9999999 Error isn't diagnostic in this case.Â
If you restart what happens?Â
August 8, 2019 at 1:54 pm
Noushin
SubscriberI have restarted the same workbench project, using standalone, using fluent, using components several times but each time the fluent window disappears without any notice. And in the folder where the .cas and .cdat files are stored, I get this error message [Abnormal exit]
August 8, 2019 at 3:23 pm
Amine Ben Hadj Ali
Ansys EmployeeAre you running an remote nodes? -
August 8, 2019 at 3:42 pm
Noushin
SubscriberNO SIR
August 8, 2019 at 3:45 pm
Amine Ben Hadj Ali
Ansys EmployeeScreenshot of Fluent launcher showing all settings in all sub TABS -
August 8, 2019 at 4:20 pm
August 8, 2019 at 4:47 pm
August 8, 2019 at 5:16 pm
August 8, 2019 at 7:47 pm
Amine Ben Hadj Ali
Ansys EmployeeThen might be related to network issues. Try locally (copy project to harddisk or local disk) if the problem does occur and check with your IT. -
August 10, 2019 at 2:57 pm
August 12, 2019 at 4:45 am
Amine Ben Hadj Ali
Ansys EmployeeNice. Check Why Connection was broken and mark this as Is Solved.
- The topic ‘REquesting Help regarding Abnormal Exit from Fluent issue’ is closed to new replies.
5059
1770
1387
1248
.jpg?width=690&upscale=false)
