Comparison of theory and simulation
    • Il Sun Hwang
      When I solve the problem in the picture above, what should I see as the simulation stress value??
      The results are the most similar in average value.
      But the example is cross-sectional and the simulation is volume. It's confusing.
    • ErKo
      Hi
      It (max min variation) is because of the stress singularity at fixed location and between them 2 (at contact location) – look at stresses away from these points and say in the middlle of the 2 members.
      Even better is to use beam elements (1D line elements), where this does not happen (singularity). For the right wall (0.4 mm gap) one can usse a translational joint at the end of the copper rod with a stop of x=0.4 mm.
      All the best
      Erik
    • ErKo
      Hope all this helped since it might be of use to others we can close the post as it has been answered.
  • The topic ‘Comparison of theory and simulation’ is closed to new replies.
