Herschel-Bulkley model disappeared in new version?
    • Teun Vandermeulen
      I am modelling a fluid through a microfluidic device that behaves according to a Herschel-Bulkley fluid model. Normally, I can use this model in the Create/Add Materials window under Viscosity. However, I recently installed the newest version of Ansys Fluent (2024 R1) and this function seems to be disappeared (see image). Is there any way I can access this again?
      Thanks!
      Have you got a turbulence model switched on?
  • The topic ‘Herschel-Bulkley model disappeared in new version?’ is closed to new replies.
