Ansys Learning Forum Forums Discuss Simulation General Mechanical Write the parameter value to a text file Reply To: Write the parameter value to a text file
dlooman
BFE,TEMP is a "structural" temperature not a thermal analysis temperature.  Normally the nodal temperatures are of interest so nsol,2,node number,temp is used.  I don't see a way to plot the average element temperature in post26 so you for that you have to use post1 as Matt mentioned:
/post1
set,,,,,time
etable,e_temp,temp
pretab,e_temp
