June 5, 2024 at 11:31 am
hu xiaowei
SubscriberHow to perform transient calculation of axial flow compressor acceleration using CFX
August 7, 2024 at 4:32 am
Yuanyuan Xiao
Ansys EmployeeHi Xiaowei,
Sorry for late. Due to AIS system maintenance in June, your question was automatically closed, and I was unable to respond at that time. I’ve only just now been granted permission to reopen and reply to your question. I apologize for the late response and appreciate your understanding.
The answer for your question is as below:
• The general workflow is:
‐ Set the Analysis Type to Transient
‐ Specify the transient time duration to solve and the time step size
‐ Set up physical models and boundary conditions as usual
• Boundary conditions may change with time
‐ Prescribe initial conditions
• Use physically realistic initial conditions, such as a steady solution
‐ Assign solver settings
‐ Configure transient results files, transient statistics, monitor points
‐ Run the solverThere is tutorial called "Chapter 14: Flow in an Axial Turbine Stage"
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v242/en/cfx_tutr/i1342578.html
Hope they are helpful to you. Thank you.
March 12, 2025 at 2:55 am
hebemiley
Subscriber- Model Setup: Begin by creating a detailed 3D model of the axial flow compressor, ensuring that all geometrical features are accurately represented.
- Mesh Generation: Generate a high-quality mesh that captures the flow features, particularly around the blades. A finer mesh may be necessary in regions with high gradients.
- Define Physics: Set up the physics for the simulation. This includes defining the working fluid properties, boundary conditions, and initial conditions. Ensure that you select the appropriate turbulence model for transient simulations.
- Transient Settings: In the CFX setup, configure the simulation to run in transient Paper io mode. Specify the time step size and total simulation time based on the dynamics of the compressor operation.
- Boundary Conditions: Apply appropriate boundary conditions, such as inlet velocity profiles and outlet pressure conditions, to simulate realistic operating conditions.
- Solver Settings: Choose the solver settings that are optimal for transient calculations, ensuring that the solver can handle the time-dependent nature of the flow.
- Run Simulation: Execute the simulation and monitor convergence. Check for stability and ensure that the results are physically realistic.
- Post-Processing: After the simulation completes, analyze the results using CFX-Post. Look for key performance indicators such as pressure ratios, flow velocities, and any transient phenomena like surge or stall.
- 您必须登录才能回复此主题。
6575
1311
