Ansys Learning Forum Forums Discuss Simulation General Mechanical Result shows same value for max and min Reply To: Result shows same value for max and min
Kaushal Vadnere
Thanks for the details,
Are you applying 100kN as UDL?
For safety factor, what's the minimum value, can you put a screenshot for the safety factor contour as well?
Also, can you share details of fatigue tool (possibly a screenshot) to see what loading and options you've selected?
For your other question, you can find the definitions for fatigue life, safety factor, etc in the Ansys Help > Mechanical Users Guide here: 18.11.5. Fatigue Results (ansys.com)
Also, you can refer to this free TIDBIT on fatigue analysis, you will find a collection of knowledge materials that will provide you with some tips and tricks for performing a fatigue analysis in Ansys Mechanical: Performing a Fatigue Analysis using Ansys Mechanical | Ansys Innovation Courses
