June 3, 2024 at 5:49 pmZwernjaydenSubscriber
I need one surface to be 1e-6m, and the rest to be 1e-4m. The geometry is a approximatly a .5mx.05m rectangle. It has been meshing for 24h and won't get past 5%. Is there something wrong or if I leave it long enough will it finish
June 3, 2024 at 7:14 pmRobForum Moderator
If you do a quick hand calc how many cells are you going to get at that resolution? If you're in Ansys Meshing there is a cap on surface facets to prevent the algorithms running away but I'm not sure what that value is now: it used to be around 100k cells.
- The topic ‘1e-6m meshing’ is closed to new replies.
Ansys Innovation Space
- Load Key value for SFE command
- ICEM CFD – Hexa mesh of a tapered wing with sharp trailing edge
- Too High Aspect Ratio
- No mesh information was found in the input mesh file error
- the matrix T in the cyclic symmetric formula!!
- Varying ply angle in ACP
- Assiging one parameter as thinkness of few shell objects
- CONVERTING STL FILE IN TO SOLID
- Element type definition – Ansys Workbench
- ANSYS ACP Modelling Issue
513
488
225
209
