Ansys Learning Forum › Forums › Discuss Simulation › Electronics › rmxprt on 2023R1 › Reply To: rmxprt on 2023R1
June 3, 2024 at 5:29 pm
GLUO
If you have the old version Maxwell model, you can export the geometry as .step file and re-import them back into the new version. This should help re-format the geometry code and fix most geometry issues. But you will have to re-assign the materials and excitations.
GL
