August 5, 2019 at 6:18 am
ANKITAPUJAHARI
SubscriberHello,
I am using supercritical co2 from NIST database to study natural convection in an enclosure. I have used density-based solver using implicit formulation and the flux type is Roe-FDS. I am starting the simulation from first order. The convergence rate is very slow. What should be done to increase the convergence rate?
Thank You.Â
August 5, 2019 at 8:40 am
Amine Ben Hadj Ali
Ansys EmployeeWhy density based solver? Any reasons for that?
Smaller time steps could be helpful there. Do not forget to switch on gravity.Â
August 5, 2019 at 9:48 am
ANKITAPUJAHARI
SubscriberDensity-based solver is because of the dependence of density on both temperature and pressure near supercritical temperature and pressure . I have tried using the pressure-based coupled scheme but the probe values are oscillating. One more thing, when I used constant temperature condition on the cold wall convergence resulted. But after using convective boundary condition the convergence rate is extremely slow. I have used steady-state solver
- The topic ‘convergence problem for super critical fluid accessed from NIST data base’ is closed to new replies.
- affinity not set
4007
1461
1287
1124
