June 3, 2024 at 7:07 am
June 3, 2024 at 3:59 pm
igandiko
Ansys EmployeeIf the two parts do not share nodes and you want to tie them together, please try *contact_tied_nodes_to_surf (or surf_to_surf). *contact_tied_..._to_surface are constraint-based contacts, and nodes from surface A will be projected to master surface (surf B) during initialization. It's best to use segment sets to define surf A and surf B of a TIED contact and to include ONLY the nodes or segments you wish to be tied. In this way, any warnings of untied nodes are actually helpful.
Note that constraint-based tied contacts should not be used in explicit analysis IF there are other constraints (SPCs, prescribed motion, rigid bodies, etc) associated with the slave or master surface. Otherwise, they should be fine. The contacts cards with the word "OFFSET" (unless it says constraints_offset) are all penalty-based contacts. Please see LS-DYNA user's manual for more information.
June 4, 2024 at 1:11 am
yjg298
SubscriberThanks for your reply. But I want the two parts to share nodes. Can I still use CONTACT_TIED_NODES_TO_SURF?
June 5, 2024 at 5:55 pm
igandiko
July 16, 2024 at 4:24 pm
wissem chakchouk
SubscriberHelloI have the same problem: I want to share the nodes for these two parts (blue and red), which options I can use Contact_surface_to_surface or Contact_node_to_surface and what is the difference between them in the results.Also, I have no idea how to change the settings of this module and what the main settings are(These settings as it shows is by default).Thank you in advance.
July 16, 2024 at 4:05 pm
wissem chakchouk
- The topic ‘CONTACT_TIED’ is closed to new replies.
6435
