Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › HFSS Modeling › Reply To: HFSS Modeling
May 31, 2024 at 2:30 pm
Hi Francesco,
Thank you for reaching out to the Ansys learning forum.
Please share screenshots of your issue if possible to help us serve you better.
For your first observation: you might be zooming onto the origin and see the trace is not passing through the origin - this is just a render issue after you zoom in from a certain point. You can verify using the measure option in the draw ribbon area.
Best regards,
Praneeth.
