Ansys Learning Forum Forums Discuss Simulation General Mechanical ACOUSTIC – FLUID STRUCTURE INTERACTION Reply To: ACOUSTIC – FLUID STRUCTURE INTERACTION
ErKo
Hi
Do not use the ACT extension.
Use the ANsys native acoustics systems called Harmonic Acoustics.
See here for a tutorial
https://www.youtube.com/watch?v=Kq3iuYK52gc
Also now when you have acoustic domain on one side only of the shell, that is OK - use shared topology so share nodes on the interface between the 2 domains and avoid using contacts between them (see tutorial where share topology is used) .
(As we said we can not have an acoustic domain on both sides of a shell/surface body, but on one side like shown in the image is OK)
All the best
Erik
