Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Torque- speed curve › Reply To: Torque- speed curve
May 30, 2024 at 2:30 pm
GLUO
In RMxprt you can right click Results>>Solution Data to access the curves. In Maxwell you need to create a variable as speed, and sweep it in parametric to get solution for all speed, then plot the curve.
GL
