Simulation of combustion of LNG and LOx in CD nozzle
    • Hitendra Singh
      So i want to study the temperature, velocity and pressure of the flow coming out of cd nozzle after the combustion process inside the chamber. 2 different inlets are provided, one for liquid methane (LNG) and another for liquid oxygen (LOx) and i want them to get mixed and ignite inside the chamber. I am not understanding why the flow is going downwards and velocity of flow is maximum at throat and decreasing further. Any suggestion would be appreciated.
      Mesh:
      Target skewness: 0.9 (Default)
      Number of nodes: 176174
      Number of elements: 175014
      Setup:
      1. Solver:
      Pressure based, steady and absolute
      2. Model:
      k-epsilon standard with standard wall function and curvature correction
      3. Species:
      Non premixed combustion with Inlet diffusion, chemical equilibrium and non-adiabatic enabled at standard atmospheric operating pressure.
      3.1.  Boundary:
      CH4 = 1 and O2 = 1 with fuel temperature 90K and oxidizer temperature 60K.
      3.2. Calculated Pdf table.
      3.3. Radiation is enabled as Discrete ordinates
      4. Boundary Condition:
      Fuel inlet (mass flow inlet)
      Mass flow inlet = 0.017 kg/s
      Initial Gauge pressure = 2465000 Pa
      Turbulent intensity = 10%
      Mean Mixture Fraction = 1
      Mixture Fraction Variance = 0
      Oxygen inlet (mass flow inlet)
      Mass flow inlet = 0.026 kg/s
      Mean Mixture Fraction = 0
       Outlet (pressure outlet)
      Gauge pressure = 96500 Pa
      Initialization method: Hybrid
    • vinaraya
      Hi Hitendra,
      Is the combustion complete? has all the reactants converted to products ?
      Could you share the contours of mass fraction of O2, CH4 and product species like CO2 and H20.
  • The topic ‘Simulation of combustion of LNG and LOx in CD nozzle’ is closed to new replies.
