Ansys Learning Forum Forums Discuss Simulation Electronics Question Rmxprt and Maxwell Reply To: Question Rmxprt and Maxwell
NKC
I wrote X turns because I do not know how many turns you have for that case.
According to your explanation, as I understand it, there are 7 turns per phase in your winding and each turn has a single wire of 0.55mm dia. For this, you need to use 0.55 mm as the diameter of the wire with the number of strands as 1.
Navya
