Ansys Learning Forum Forums Discuss Simulation Electronics Objects with small model dimensions in Ansys Maxwell Reply To: Objects with small model dimensions in Ansys Maxwell
c76zhang
Please follow up on this topic. Setting up non-model regions and equating the D field in the case where there would be oxide to calculate the participation ratio has significant limitations in result accuracy. In the 2D solver, I cannot modify the model resolution, nor can I switch to classic mesh. Taken at face value there seem to be a big limitation of the software for calculations related to thin layers.
Chi Zhang
