Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Metal forming (spinning) › Reply To: Metal forming (spinning)
May 24, 2024 at 3:22 am
Hello Zhao,
The sliding energy and contact force should indicate if the contact is the issue or not. If the contact is the issue, try the following:
- I don't have much experience with forming contacts. But, I would try SOFT=2 (segment based contacts), SBOPT=3, and DEPTH=35. If it does not work better, try the *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE with these settings instead.
- Reduce the bucket sort frequency.
- Reduce TSSFAC
Let me know how it goes.
Reno.
