Ansys Learning Forum Forums Discuss Simulation Fluids Divergence detected in AMG solver: pressure correction temperature limited to… Reply To: Divergence detected in AMG solver: pressure correction temperature limited to…
S.Shrestha-4
It’s not clear how I can set it up differently. My inlet velocity is around 0.004 m/s and there is no restriction set at outlet which says liquid can not come out. It would be ideal to have a vapor at outlet, however. As there is a nozzle downstream the channel. I have only defined static pressure at the outlet.
