Ansys Learning Forum Forums Installation and Licensing Ansys Products Lumerical installation in linux. Error while converting RPM to DEB using alien. Reply To: Lumerical installation in linux. Error while converting RPM to DEB using alien.
Lito
@Anoop Varghese,
You can try the 'extract-rpm.sh' script that comes with our installation package. Then install the list from the 'missing_packages.txt' file generated after extracting the installation files into the current working directory.  >> Installing on a shared filesystem on Linux – Ansys Optics
Do take note that we do not support Linux mint. >> System Requirements – Ansys Optics
