Ansys Learning Forum Forums Discuss Simulation Fluids Divergence detected in AMG solver: pressure correction temperature limited to… Reply To: Divergence detected in AMG solver: pressure correction temperature limited to…
And you've fixed the wall temperature, or fixed the heat flux? What happens in the early stages if you initialise the domain to be full of water (think about the physical aspect as opposed to the solver)?Â
