Ansys Learning Forum Forums Discuss Simulation Electronics Variable Dimension Problems Reply To: Variable Dimension Problems
Taiye Owu
Hi, Please I have tried all the advise it still doesnt work. Below is when I want a 2mm spacing between my lines, I created a variable defined the type and unit as adviced. But when I define the lenght as 2, it basically almost overlaps , but if I use 2000 it gives me the spacing of 2mm it's giving me a lot of trouble and I can progress with my project. please refer to the images attached.
Now this is when I define it as 2, it basically overlaps as though no spacing between
Please I need help, as I have followed all the instructions. Thank you so much
