Update dynamic mesh failed. Negative
    • jil260
      I ran a fluent case: wedge falls into the water.  Here is the problem
      How to solve this?
    • Raef.Kobeissi
      There are many factors to consider:
      1. Type of mesh (try using tetrahedral)
      2. Time step, start with a relatively small time step
      3. Mesh resolution, make sure to have a better mesh resolution
      Depending on the type of problem you are trying to solve you need to use the correct setup for dynamic meshing.
  • The topic ‘Update dynamic mesh failed. Negative’ is closed to new replies.
