Ansys Learning Forum Forums Discuss Simulation Photonics Is it possible to optimize multiple parameters at a time using Parameter sweep? Reply To: Is it possible to optimize multiple parameters at a time using Parameter sweep?
Guilin Sun
I guess you mean you are doing sweep in order to get the phase values corresponding to each set of dimensions. If so, you will need nested sweep:
https://optics.ansys.com/hc/en-us/articles/360034922913-Creating-nested-parameter-sweeps
Optimization on the other hand can reach your predefined FOM, which will not save result for each parameter.
"Is it possible to concatenate all 9 sweep results and have the phase values together? "
Not sure what does this mean. For each sweep, such as diameter, height, can be cascaded as illustrated in small metalens example in "height" sweep. Please refer it and let me know if you have questions.
Best wishes
