Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › 3D Tire Modeling using Ansys Mechanical Static Structural – Help !! › Reply To: 3D Tire Modeling using Ansys Mechanical Static Structural – Help !!
			May 15, 2024 at 11:39 am
	Hi Peter, just to tell you that I managed to make the PULL-Revolve command properly, it just requires that the connections between the several parts have already been defined in Space Claim or (cad) before applying the revolve command and everything works ok.Â
But I´m still having problems with the simulation, i have started a new discussion about it, 3D tire Static Structural...
Thanks for all the support :)
 You are navigating away from the AIS Discovery experience
