Ansys Learning Forum › Forums › Discuss Simulation › Platform › Solving Two Way FSI over HPC › Reply To: Solving Two Way FSI over HPC
May 14, 2024 at 8:22 am
Rahul
Hello Anas,
Just ensure that you are using correct files on your HPC and check if all the participants files are transferred to HPC.
To run co-simulation at least two coupling participants, one interface, and one data transfer is necessary.
I would recommend you to follow this workshop and refer to user manual to know more about workflow.
Solving Co-Simulations from the Command Line (ansys.com) and Reed Valve FSI Co-Simulation with Partial Setup Export from Workbench (Fluent-Mechanical) (ansys.com)
Using Parallel Processing Capabilities (ansys.com)
Hope this helps!
