Torque of wind turbine
    • Azam Deen
      I've been trying to simulate wind turbine to plot the graph of power coefficient vs tip speed ratio by using MRF method. But the torque always converge to negative values. Was it due to the interface or need to refine the mesh.
    • Federico
      How did you set up your torque calculation? Are you sure that you have the rotation set up correctly?
  • The topic ‘Torque of wind turbine’ is closed to new replies.
