TAGGED: Lumerical-FDTD, lumerical-script, parametric-sweep
May 13, 2024 at 8:06 pm
Arpan
SubscriberHello. I have been trying to set up a Lumerical FDTD simulation for running structure optimization and sweep of a solar cell. For this, I have declared a structure group of solar cell layers with the layer thickness value as input user-defined parameters. I have also tried to set the FDTD and monitor dimension based on the user-defined solar cell structure group properties. For the later part, I have added the following code in the model setup script.
select("PSC_pin");
set("h_HTL_1", HTL_zspan);Â #sweep variableÂ
set("h_ABS", PSC_zspan); #sweep variableÂ
runsetup;
select("PSC_pin::BC");
PSC_zbottom = get("z min");
select("PSC_pin::TCO");
PSC_ztop = get("z max");
offset_src = 200e-9;
src_z = PSC_ztop+offset_src;
select("source");
set("z", src_z);
FDTD_offset = 100e-9;
FDTD_zmax = src_z+FDTD_offset;
FDTD_zmin = PSC_zbottom-FDTD_offset;
select("FDTD");
set("z min", FDTD_zmin);
set("z max", FDTD_zmax);
select("PSC_pin::HTL_1");
solar_ztop = get("z max");
select("PSC_pin::ETL_1");
solar_zbottom = get("z min");
solar_z = (solar_ztop + solar_zbottom)/2;
solar_zspan = solar_ztop - solar_zbottom;
select("solar_generation");
set("z", solar_z);
set("z span", solar_zspan);
runsetup;Â
When I ran the sweep, the structure, FDTD domain, and source position were updated in the newly created .fsp files but the monitor dimension remained the same. Outside of sweep, I tried changing the thickness parameters from the model's setup variable section. But for the monitor to be updated properly, I had to click the 'test' twice.
After clicking "test" first time, I had the message that the structure group script had run. After clicking "test" second time, I had the message that the solar generation analysis group script had run.Â
What should I do to run the sweep using this setup properly?
May 14, 2024 at 3:34 pm
Guilin Sun
Ansys EmployeeÂ
I believe you need script to control the monitor in the analysis group. When you change the z-span of “solar_generation”, does it apply to the monitor location? if not, please try to set the monitor position with a variable related to z-span or a new parameter.
- The topic ‘Solar monitor position not getting updated while using script in model setup’ is closed to new replies.
