Ansys Learning Forum Forums Discuss Simulation Embedded Software et_studio_eclipse does not exist in the licensing pool Reply To: et_studio_eclipse does not exist in the licensing pool
Benjamin Descorps
First of all, you should verify that you have set the environment variable ANSYSLMD_LICENSE_FILE on your machine. This variable should point to the license server in the following way: @. The default port number value is 1055. The hostname corresponds to the name of your license sever.
Example:
Hope this helps,
Benjamin
