Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Lumerical version change results in output discrepancy › Reply To: Lumerical version change results in output discrepancy
May 10, 2024 at 3:44 pm
For source amplitude, please use the default 1v/m, except you are doing some non-linear effects;
Small change of phase usually is ok, in particular when the real or imaginary part of the field or S parameters is too small. you can use wunrap to avoid 2pi jump.
Please check the real and imaginary parts.
