3D Design
3D Design
Importing wind turbine blade profile geometry
    • Gianluca Cipriani
      Hello, I'm trying to import in Discovery the 2D profile of a wind turbine blade, then I will correct the chord and twist angle for every section spanwise. The airfoil points are on a .txt file, but I don't know the correct format. In fact when I use the "insert geometry" command I get a file format error in the first row. The text file is organized in 5 columns: the first has all 1, the second has the point numbers (from 1 to 62), the third and fourth have the x and y coordinates, the last one has all 0 (z coordinates). Can please someone give me any advice? Thanks in advance.
    • Devendra Badgujar
      I will have to check if this is possible, and get back to you on this.
      Devendra
  • The topic ‘Importing wind turbine blade profile geometry’ is closed to new replies.
