May 9, 2024 at 5:52 am
satyam
SubscriberHi, I have a blade divided into two parts using Overset mesh. The first half of the blade is rotating about 0 0 and the second half relative to first half so 0 0. Now i want to rotate the second half about its own axis using 1 DOF spring connection with certain K. Everything works well. When I am activating the 6DOF solver and putting certain values in the , it asks for center of rotation in case of rotational spring 1DOF. In my case, it would be the blade's second half pitching point. But, there is no way to put the daming for the spring, how can i use a damper in this case? -
May 9, 2024 at 5:54 am
- The topic ‘1 DOF spring using dynamic mesh in combination with sliding and overset mesh’ is closed to new replies.
- Is it able to solve turbomachinery using density-based solver in Fluent?
- Two-way FSI simulation
- Ensight Force_per_unit area_EV
- RIBBON WINDOW DISAPPEARED
- Fluent Meshing Error when .dsco not .stp
- Ansys Fluent for modelling Ocean Wave reactions to Wave Barriers
- Battery Pack cooling
- ISAT ABORT error
- UNASSIGNED INTERFACE ZONE DETECTED FOR INTERFACE…
1494
1386
1209
