Ansys Learning Forum Forums Discuss Simulation Photonics Farfield simulation and monitors Reply To: Farfield simulation and monitors
Guilin Sun
The max radiation angle that the monitor can pick up is like what is shown above (inside the material. Outside it is the refracted angle). If this angle is larger than the angle creating total internal refelction, it should work. Otherwise you need to increase the simulation span.
