Ansys Learning Forum Forums Discuss Simulation Fluids Floating point stirred tank using DPM Reply To: Floating point stirred tank using DPM
Remember that if you're adding particles to the wall surface that it's the particle centre that's added there, so they're inside the viscous sublayer and may not want to move. Inject from a little higher up. With a volume fraction that low the particles shouldn't influence the flow, and are unlikely to collide - you shouldn't need the collision model.
