Ansys Learning Forum › Forums › Discuss Simulation › Fluids › depth averaged velocity › Reply To: depth averaged velocity
May 7, 2024 at 9:10 am
I'm not quite sure I follow. Adding a vertical line at certain positions will let you get the average value on that line. Other data can be extracted from surface (planes, transform and isosurface). So you can create an isosurface of the water free surface, and then transform that by a value to get the surface at depth.
