Ansys Learning Forum Forums Discuss Simulation Photonics Heat simulation Reply To: Heat simulation
Guilin Sun
From the error messages it seems this file might be crashed.
If you can still open the file, please check the material settings and the simulation settings. When there are curves it might need much finer mesh. So please try to change min-edge length, lower triagle quality and mesh sensitity and see if it improves.
