Workbench Tree/outline
    • averham30
      Hey guys I have the R2 2019 version, so I accidentally in the steady-state thermal exited out of my tree/outline and I can't seem to reset to get it back. Through google I've found in version 18.2 to go to the view tab and reset window but the 2019 doesn't have a view tab so any help would be greatly appreciated.
      There is a Quick Launch "search" field in the top right of the ribbon bar.
      Type reset in the field and it will show you a link to the Reset Window Layout button, which is on the Home Tab.  Just click the link to execute the command.
    • averham30
      Hi thanks for the reply, so I've done that before in the past but I've just ended up with this sidebar and not the whole tree. Thank you for taking the time to help!
      Congratulations!
      Click on the little arrow to the right of the disc icon (top left of window) & deselect minimize the ribbon. If you've lost the bars/menus on the left (hard to tell from the image) once the ribbon is back look under Home (tab) right hand side "Manage".
    • averham30
      That worked! Thank you so much, now I know how to fix this issue if it occurs again.
    • ksalgado145
      How do I get my outline to look like the image below?
      This is what it currently looks like, thank you in advance!
Viewing 5 reply threads
  • The topic ‘Workbench Tree/outline’ is closed to new replies.
