Ansys Learning Forum Forums Discuss Simulation Fluids Reg: Submission script to submit job on HPC Reply To: Reg: Submission script to submit job on HPC
Swapnil
I tried giving the system coupling path and I am facing the following error now.
application-specific initialization failed: Can't find a usable init.tcl in the following directories:
    /home2/polyflowbuilds/buildagents/milpolybld01/work/1210bc2a0080eb69/Tcl-tk/8_5_11/linx64/Release/tcltk/lib/tcl8.5 /usr/lib/tcl8.5 /lib/tcl8.5 /usr/library /library /tcl8.5.11/library /tcl8.5.11/library
This probably means that Tcl wasn't installed properly.
Log file:
MPI Option Selected: intel
| Errors were found during data model validation.                             |
Error: To begin a coupled analysis setup, define at least two coupling
    participants, one interface, and one data transfer.
Traceback (most recent call last):
  File "PyLib/main/Controller.py", line 204, in
  File "PyLib/main/Controller.py", line 199, in _run
  File "PyLib/main/Controller.py", line 115, in _executeScript
  File "PyLib/kernel/commands/__init__.py", line 34, in readScriptFile
  File "PyLib/kernel/commands/CommandManager.py", line 203, in readScriptFile
  File "Scycpl.py", line 2, in
    Solve()
  File "PyLib/kernel/commands/CommandDefinition.py", line 74, in func
  File "PyLib/kernel/commands/__init__.py", line 30, in executeCommand
  File "PyLib/kernel/commands/CommandManager.py", line 165, in executeCommand
  File "PyLib/cosimulation/externalinterface/core/solver.py", line 137, in execute
  File "PyLib/cosimulation/solver/__init__.py", line 123, in solve
  File "PyLib/cosimulation/solver/__init__.py", line 499, in __checkSetup
  File "PyLib/cosimulation/datamodelrules/__init__.py", line 270, in raiseValidationError
RuntimeError: Errors were found during data model validation.
Shutting down System Coupling compute node processes.
