Ansys Learning Forum Forums Discuss Simulation Fluids Two way FSI – Run time Error Reply To: Two way FSI – Run time Error
Rahul
Hello Abhishek,
When running System Coupling and it stops running, the first thing to do is examine the output files for each solver to look for clues to what happened. For Fluent, look at the transcript .trn file. For Mechanical, look at the .out file. For CFX, look at the .out file. Also, look at the System Coupling log file, scl. You can also try re-running the case and stopping it just before the timestep when it crashes, then examine the mesh in Fluent or CFD-Post to get more clues.
From error messages in your case, it looks like it is failing in transient structural system. Please check the .out file to understand the source of error.
