Ansys Learning Forum Forums Discuss Simulation Photonics Far-field planar mode projection Reply To: Far-field planar mode projection
Guilin Sun
Negative sign is ok, as you can see from the definition https://optics.ansys.com/hc/en-us/articles/360034405254-overlap-Script-command it uses absolte value.
