Ansys Learning Forum Forums Discuss Simulation Fluids using a solution as a starting point Reply To: using a solution as a starting point
1900307
thanks rob, just final question, in the 1st & the 2nd question would i need to intialize and if so does that cancel what i did.
i mean if i changed the vector would the i need to start, or could i use the niterpolate files.
