3D Design
3D Design
Slice geometry in .stl file
    • Adrián Oya
      Hi!
      I'm trying to generate a slice in a .stl geometry in DesignModeler but it doesn't allow me.
      Do you know how can I do that?
      Open the .stl file in SpaceClaim.  On the Design Tab, select three vertices (or one facet) and click the Plane tool.  You can also move the Plane around using the Move tool  On the Facets tab,use the Split tool.
  • The topic ‘Slice geometry in .stl file’ is closed to new replies.
