Ansys Products
Ansys Products
Upon employing Simplorer for circuit simulation, an error occurred whilst import
    • 576650550
      Upon employing Simplorer for circuit simulation, an error occurred whilst importing the SPICE model:
      Error 10554 - Unable to link a connection.Model: AD8672_1.GSY Node: 2.24E-3<0>>> Prepare
      but the SPICE model was obtained from the company’s official website.
      The issue highlighted that the specified node does not exist. it is merely a statement of this nature:
      GSY 99 50 POLY(1) 99 50 2.24E-3 15E-6.  just a parameter
      The circuit’s operation is capable of yielding results, but outputs are wrong ,the output of the operational amplifier is saturated, yet the voltage amplitude fails to reach the supply voltage of 12 volts.
      What could possibly be the issue?
    • HDLI
      Hello Jingxuan,
            The Twin builder/Simplorer only has Spice compiler type either to Berkeley Spice or PSPICE, not for all the Spice types. You may need to modify the code of the Spice model to make it work. Thanks.
      HDLI
  • The topic ‘Upon employing Simplorer for circuit simulation, an error occurred whilst import’ is closed to new replies.
