Ansys Learning Forum Forums Discuss Simulation Platform Continue an interrrupted system coupling simulation Reply To: Continue an interrrupted system coupling simulation
Iheanyi Ogbonna
Hello Federico,
Thanks for your response, yes I am passing displacements to fluent, as the displacement from the last time-step is visible in fluent results.
With regards to Mechanical, yes, large deformations are turned on.
The simulation continues smoothly unless interrupted. From which it doesn't continue. I suspect a bug probably, as this is not the case when it is interrupted at lower time displacements.
